Hi
Sorry if this is covered already, but i neead a quick answer 🙂
When using a backupscript to create a backup, is it still only supported to backup to "local disks"?
or is there a way to configure the script to backup to an UNC or mapped location?
Svein
Solved by paul.gunn. Go to Solution.
This is possible - but does require some configuration to get the security permissions right. The advanced configuration guide has a section on setting up a remote backup location that should be useful:
http://wikihelp.autodesk.com/Vault/enu/Help/Help/0206-Autodesk206/0264Advanced_Configuration
Paul
