Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Vault Virtual Server
3 REPLIES 3
steamer90638
1195 Views, 3 Replies
We are looking at going to Virtual servers in 2014. We currently run  WG Vault 2013. Is anyone running 2013 in a virtual server. I kind of need some specs to shoot for.
3 REPLIES 3
ryan
in reply to: steamer90638
We have many customers successfully running Vault server on a virtual environment.   If you look to the vault readme it gives some general comments about virtual machines.    Your allocation of hardware resources for the VM should comply with the system requirements for vault.
Ryan Small
National Team Leader, Data Management and Software Development
SolidCAD, a Cansel Company (an Autodesk Platinum Partner)
www.solidcad.ca
scottmoyse
in reply to: ryan
One of the best practices of using Vault is to have a testing environment. Often that means a Virtual Machine. It's fully supported & I know of a number of people running VM Vaults in production. Like Ryan said just make sure it has plenty of the resources it requires assigned. I would exceed the recommended specs by some way if I were you.
Scott Moyse
Design & Manufacturing Technical Services Manager at Cadpro New Zealand
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
Just one more add to the correct statements on this here: please also consider the recommendations from Microsoft on virtual machines. Links can be found on the readme as well.
Kevin Jaufmann-Ludwig
Technical Support Specialist
Link Name | Link Name | Link Name | Link Name
