I noticed a problem on internet explorer with DWG files. When you have the preview image poped up, first you don't have the DWF icon on the bottom of the preview window, then if you want to download the file it doesn't resolve the real name and extension so you can't directly open it.
The attached files show the problem on the same file (same vault, same user). I know that I can't see the DWF in firefox but at least firefox can download the file properly.
The DWF exists and I don't have the problem with the old webclient (I can open the DWF embedded in IE).
So my questions are :
- is that normal that I can't see the DWF icon in the new thin client ?
- is there any way to have the file downloaded as is should ?
Does anyone reproduce this or I'm the only one who can't see autocad DWG in the 2014 Thin Client ?
Hi Aguitton116,
Could you kindly provide the build number for your Vault Thin Client 2014? (You may look for it under "programs and feature")
I noticed you are using IE8, which is not supported as of now, currently supported IE versions are IE9 and above.
Regardless, I will do some verification and testing on the issue you have reported and see if it can be reproduced on my side.
Thank you.
