Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Vault Revision Table
6 REPLIES 6
cbenner
597 Views, 6 Replies
Is anyone using the Vault Revision Table?  Vault Pro 2013 or anything close?  Have you gotten it to work?
I have tried it with the default settings, and with picking standard and/or custom properties.  Every time in Inventor that I place a Vault Rev table, it comes in with the settings of my custom "regular" revision table.  What do I do to get the Vault table to come in using the properties I set up for it IN VAULT?
6 REPLIES 6
Mpendlebury
in reply to: cbenner
Think im making slow progress, havent gotten it to work but It's alot harder than it needs to be.
it's not like every single drawing needs to be issued for construction needs a titleblock and rev table, but using civil 3d i might be dreaming.
yingkit(Autodesk)
Hi Chris,
I would like to recommend this article "Setting Up Vault Revision Tables" which also includes a video clip.
The Revision Table settings in Vault does not control the settings in the revision table that is placed in Inventor. Rather, we enter the exact words used in the drawings' revision table column for the Column Header value while configuring the Revision Table Settings.
Kit
Ying Kit
alan_ho
Hi cbenner,
Ying-Kit is right, the Vault revision table does not control the styles of the Inventor drawing.
You would require to custom the Revision Table styles in the drawing templates within your workgroup.
I have just posted a link on how this can be done:
http://forums.autodesk.com/t5/Autodesk-Vault/Vault-revision-table-and-Autocad/m-p/3519888#M43147
Hope this helps.
Alan Ho
Principal Experience Designer
Digital Platform & Experience
Autodesk, Inc.
cbenner
in reply to: alan_ho
CAD-One
Great tips. Useful information. Thanks
C1
Inventor Professional 2020
Vault Professional 2020
AutoCAD 2020
