I am trying to replace an Xref with an Identical Xref (only different Project.Filename) in Vault.
When I highlight the particular Xref (or any Xref for that matter) and pick Edit | Replace... I get the same "Restriction" error message window pop up....every time.
Please refer to the attached....
What exactly does the message mean and how can I make this work?
Note: I am trying to replace existing old drawings with existing (identical except for project number) "new" drawings in Vault. All drawings were copied designed and given different project numbers accordingly.
I have administrator rights if required....
Cheers
David
Hi dpenney,
Please go to http://forums.autodesk.com/t5/Autodesk-Vault-IdeaStation/idb-p/2 and submit an enhancement request if you would like to see this feature enabled for Autocad Mechanical and Electrical files.
