Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Vault Pro 2014 - Print Change Order, Error "Given Key not Present"
3 REPLIES 3
steveh4
462 Views, 3 Replies
Getting an error with VP2014 Client (SP1). Says that "Given Key was not Present in Dictionary". Get same error on all workstations.
FYI...If I log into VP2013 Client, I can print it with no error.
Screen shot attached....
Inventor---Vault Professional
3 REPLIES 3
Senthil_Kumar
in reply to: steveh4
Thanks for reporting this issue. We are aware of this issue and it is already logged in our system.
Senthil Kumar
Development Manager,
Autodesk, Inc.
Be sure to check out the Vault Help!
gerry_treacy
Has this been fixed yet? I'm getting the same error. Vault Pro 2014 Sub Rel 1, update 1.
samuel.seah
in reply to: gerry_treacy
Unfortunately, no Smiley Sad In the meantime, you will have to open the change order and then select print from the File menu.
Samuel
