Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Vault Pro 2014 Data Standard extension - setting it up
2 REPLIES 2
mark.cloyed
708 Views, 2 Replies
I am trying to test the data standards extension for VP2014, specifically with AutoCAD.  I am struggling with how to get it set up within the AutoCAD context.  I did not see an AutoCAD.cfg file included with the download, so I have copied one from another's Inventor post.  I am questioning whether it is correct.  I also am questioning how to initialize the functionality within AutoCAD.  Do I need to netload a component?  is there a partial menu to load?  I see the help refers to a ribbon tab to enable the data standard, but I don't see where that comes from to load.  I am attaching my AutoCAD.cfg file for reference.
Mark
Mark Cloyed
IMAGINiT Technologies
Tags (2)
2 REPLIES 2
mthomas
in reply to: mark.cloyed
Mark,
There should be three installers as part of the Data Standard download. For the AutoCAD components you need to install the AutoCAD using the specific MSI. This should both create the .cfg and the menu items into AutoCAD.
If you've installed this I'd re-download and re-install
The AutoCAD.cfg should be in C:\ProgramData\Autodesk\Vault 2014\Extensions\DataStandard\CAD\Configuration
Mike
Mike Thomas
Tags (1)
mark.cloyed
in reply to: mthomas
Thanks Mike. That was the solution. Life is good!
Mark
Mark Cloyed
