In 2010 we could multiselect (shift-ctrl) files for check out and undo check out etc... I'm dealing with non-cad data so no worries about that end of things... but what happened to that? Is it toggleable?
Solved by ebuckner. Go to Solution.
Solved by luttena. Go to Solution.
That command and workflow should still be available. If you are not seeing the 'Get/Checkout' command, then let me know more about your selection set and what release of Vault you're using.
Thanks!
Adam
We are using Vault Professional 2012, under cet/checkout we cannot multiselect, get/checkout works it's just that the user has to select files to checkout one at a time.
Ok. I think I see what you mean now. If you change the view to details view, you can multi-select (Shift-select or ctrl-select) and right click on those selected files. From the context menu, select 'Check'.
Let me know if that works for you.
Adam
