Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Vault Manufacturing Error
3 REPLIES 3
vallourec
257 Views, 3 Replies
I have an error everytime i launch Vault and after i see this red cross instead of the "add group" function.
For information when i'm connected on this pc with another windows user name it's work fine...
Could you please help me to solve this problem ???
Thanks for your reply
BELLEMERE JP
3 REPLIES 3
vallourec
in reply to: vallourec
After this first error i have this one also when i try to send the document by mail.
youc
Can you always reproduce the red cross on the client?
If it's caused by the UI layout issue, you may need to delete all the xml files under "C:\Documents and Settings\%user%\Application Data\Autodesk\Autodesk Vault Manufacturing 2010\Objects" and restart Vault, it will help to clear the history information of client UI layout. If this does not work, perhaps restarting ADMS is a way worth trying.
Carol
vallourec
Hello and thanks for your reply,
I 've ever delete the user profiles but the error still there...
I'll try to restart the adms server but i'm not sure it'll correct the error as the other user haven't this problem...
Bellemere JP
