Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Vault / Buzzsaw Project Sync
2 REPLIES 2
331 Views, 2 Replies
We use the Project Sync quite frequently and for the most part it is a very capable utility.
I was wondering if anyone had thoughts on how to monitor the sync process a little more closely.
Through observation and reviewing the Buzzsaw Activity log, one can deduce what types of files cause
problems -namely those that are checked out and those larger than 250MB in our experience.
We have ours set to Sync continuously and it seems to trigger on file activity while remaining Idle otherwise- which is nice.
This part probably goes in the wish list, but it would be very helpful if the user could see file-by-file feeback
in the Job Processor for Sync jobs much like what happens when you 'Send to Buzzsaw' a specific folder or set of files.
A progress bar of some sort would be helpful in this case; when syncing a large segment of Vault, the user really only sees the start
time of the job and an Idle state when finished.   While you can refresh the Buzzsaw Activity log, seeing file-by-file status would
help pinpoint the cause of hangs or version-up loops.
A common occurence for us is:   Consultant updates a file in Buzzsaw
                                                 Several hours later the Sync to Vault has not occurred
                                                Job Processor is reset
                                                Sync Job is Paused and restarted
                                                Files are then synced within minutes.
I think we just wish there was a way to ensure that the Sync either succeeds or notifies in the case of a failure.  Maybe even a way to notify the recipient as Buzzsaw does through email alert.
I'd be happy to hear of how others are implementing the Sync features to collaborate.  It is a great solution for companies who need their consultants to have Vault access without the hassle of VPN login and maintaining the Vault client at non-Vault establishments.
thanks,
Blake
2 REPLIES 2
Previously we had synced an upper level folder containing several projects passed to consultants in Buzzsaw. We were quite delighted
with Vault 2015 that a per folder sync is now possible. However, when Adding Mapping with the Project Sync utility and choosing Buzzsaw folder
it takes about a few minutes to initially display the Buzzsaw folder list. Is there a way to improve performance on this or have you noticed similar issues?
thanks,
Blake
I guess what I am looking for, is there a config file associated with Project Sync that I can edit to add multiple projects without using the Project Sync interface?
thanks,
Blake
