Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Vault Basic 2013 over VPN problems seeing files
3 REPLIES 3
jmbehnke
512 Views, 3 Replies
I am running Vault Basic 2013 on a DELL M4800 mobile work station (Windows 7 Professional 64bit, 8GB ram.  When I log in to the Vault over a VPN, the vault explorer launches normally; I can see all of the folders in the file tree, but I cannot see any of the individual files in those folders.  I have applied hotfixes dl19384851 & dl19857773.
I have this same setup (Vault Basic 2013 and the VPN) on a Lenovo W700 mobile workstation running Windows XP Professional 32bit.  While it is no speed demon, it works OK.
John Behnke
3 REPLIES 3
herrerh
in reply to: jmbehnke
Make sure you install SP1 and the Cumulative hotfixes for Vault 2013.  There is a known issues before those updates that if .NET 4.5 SP1 got installed, you would no longer see fiels in the grid.
-Hywell
Hywell Herrero
Data Management Support Specialist
Product Support
Autodesk, Inc.
jmbehnke
Thank you for the input.  I will download the update - am I correct in assuming that I will have to apply the update to both the Vault server and the Vault Clients?
Thanks -
John Behnke
herrerh
While installing the Service Pack onto the client only will resolve your issue, you should install it on the server also.
-Hywell
Hywell Herrero
Product Support
Autodesk, Inc.
