Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Vault Basic 2013 on Single PC
13 REPLIES 13
Message 1 of 14
BeKirra
932 Views, 13 Replies
I don't  know much about the Vault.
I had installed vault basic with Product Design Suite Ultimate 2013 on my pc but the vault doesn't work at all.
It shows an error message when I login:
"Vault Basic 2013 could not find the Data Management Services on localhost."
I have repaired the vault but it makes no difference.
Your helps are much appreciated.
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
13 REPLIES 13
Message 2 of 14
edwin.prakoso
in reply to: BeKirra
There are two separate software: on the server side is Vault Server (or ADMS - Autodesk Data Management Server) and on the client side is Vault Client.
It looks like you only have Vault Client installed. You also need to install Vault Server.
If this post solves your problem, please mark it as solved. It will help others with a similar problem to find a solution.
Kind regards,
Edwin Prakoso
LinkedIn | Website | Twitter
Message 3 of 14
DarrenP
in reply to: edwin.prakoso
i suggest reading up on what vault is first
http://help.autodesk.com/view/VAULT/2014/ENU/
DarrenP
Message 4 of 14
BeKirra
You're right.
I have not installed the vault server (or ADMS).
There is no vault server in the installation media.
My version is "Product Design Suite Ultimate 2013".
I want to learn it at home.
Can the vault server or ADMS be downloaded from autodesk.com?
Thanks for your help.
X² + Y² = C²
Message 5 of 14
BeKirra
BTW, I just found that there is vault basic server available in the "Install Tools & Utilities" in the installation media.
But I cannot install it because there is an error message "NO Microsoft IIS is available or workable for the server" when trying to install vault server.
What does it mean?
Do I have to buy a copy of Microsoft IIS or it can be downloaded at microsoft.com?
Thanks.
X² + Y² = C²
Message 6 of 14
DarrenP
do you have IT staff available?
DarrenP
Message 7 of 14
karthur1
Thanks.
That is not what you want.  What you are looking for is "Autodesk Vault Basic Server 20xx.exe"  It is not on your installation media.  You have to download it from you subscription support page.  Here is a link that will tell you how to get there.
http://blogs.rand.com/support/2013/06/how-to-locate-the-2014-server-downloads-for-vault-basic-and-ab...
After you get it downloaded, its just a matter of running the .exe and it installs.  You will also have to install the Vault Basic Client 20xx on the machine.  I have the same setup at home on a Win 7(x64) and it runs great.
You will not have to purchase any other software just to install it for learning.  However, if you do install and run this at your work, you might want to consider purchasing a full SQL license.... just depends on several factors
Kirk
Message 8 of 14
BeKirra
in reply to: karthur1
Thanks Kirk.
This is what I am looking for.
Two more question for you,
1) I have installed "Vault Basic 2013 (Client)" from the installation media. Is it the one you have mentioned?
2) And now I need to download the "Vault Basic Server". Which one should be installed first? "Vault Basic Client" or "Vault Basic Server"?
X² + Y² = C²
Message 9 of 14
DarrenP
i usually install the server first but it doesn't matter
you can't use the client without the server anyway
DarrenP
Message 10 of 14
karthur1
I installed the Vault Client from the download on the subscription site. Both Vault Server and Vault Client are there.  Like Darren said, I would install the server first, then the client.  It would "probably" work if you put the client on first, but why chance it.
After you get them installed, check the Vault subscripton download page.  There is a service pack there for both the client and server.
Kirk
Message 11 of 14
herrerh
What operating system are you trying to install the server to?
Hywell Herrero
Data Management Support Specialist
Product Support
Autodesk, Inc.
Message 12 of 14
BeKirra
Thanks to everyone.
Finally I installed Vault Basic Server to my desktop.
X² + Y² = C²
Message 13 of 14
I am getting the same error message "NO Microsoft IIS is available or workable for the server" when trying to install vault server.  Any ideas?
Message 14 of 14
karthur1
Did you download the install files from the link that is a few messages back?
