Is the following error a sign of some bigger issue or simply that of a missing file.
5/24/2014 7:28:09 AM A file system error has occurred: Could not find file 'D:\...\000\000\000\040\001\025\40001025916\40001025916_40001025918_2.tif'.
5/24/2014 7:28:09 AM Connectivity.Application.VaultManager.ServiceException: IOError [179] (Could not find file 'D:\...\000\000\000\040\001\025\40001025916\40001025916_40001025918_2.tif'.) ---> Connectivity.Core.Exceptions.EncodableException: IOError [179] (Could not find file 'D:\Vault_Root\Filestore\TSG\000\000\000\040\001\025\40001025916\40001025916_40001025918_2.tif'.) ---> System.IO.FileNotFoundException: Could not find file 'D:\...\000\000\000\040\001\025\40001025916\40001025916_40001025918_2.tif'.
at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
at System.IO.File.InternalCopy(String sourceFileName, String destFileName, Boolean overwrite, Boolean checkHost)
at System.IO.FileInfo.CopyTo(String destFileName, Boolean overwrite)
at Connectivity.Core.Util.IOUtil.CopyDirectory(DirectoryInfo sourceDir, DirectoryInfo destDir)
at Connectivity.Server.Common.Services.FileStore.<>c__DisplayClass5.<CopyResourceStore>b__4(DirectoryInfo currentSource)
at Connectivity.Server.Common.Services.FileStore.WalkStore(DirectoryInfo currentdir, Int32 currentDepth, StoreDepth desiredDepth, StoreWalker walker)
at Connectivity.Core.Operations.Backup.BackupKnowledgeVault(DirectoryInfo databasesDir, DirectoryInfo filestoresDir, KnowledgeVault kv)
at Connectivity.Core.Operations.Backup.BackupKnowledgeVaults(DirectoryInfo databasesDir, DirectoryInfo filestoresDir, BackupContents contents)
at Connectivity.Core.Operations.Backup.Execute()
at Connectivity.Core.Services.KnowledgeMasterService.Backup(String& backupPath, BackupOptions backupoptions, ICollection`1 excludedLibraries, OnProgressDelegate onProgress)
at System.Runtime.Remoting.Messaging.Message.Dispatch(Object target)
at System.Runtime.Remoting.Messaging.StackBuilderSink.SyncProcessMessage(IMessage msg)
--- End of inner exception stack trace ---
Server stack trace:
