After installing Vault 2014 SR1, launching the new thin client and then selecting Item Manager i receive the error: "Error occurred while generating entity view" Illegal characters in path. (see image).
Thoughts?
John
Solved by zongjie.ng. Go to Solution.
HI John,
This may require a support case. Likely need a bit more detail here including server logs etc.
Hi John,
Could you also attach the image?
Thanks.
Chear Huat.
Hi Kolesaa,
Some of the listed files might contain special characters (which are interpretted as illegal character), could you help to identify are there of such character in the file name?
Thanks.
Chear Huat
Hi kolesaa,
Would that be okie if you could provide us with the dataset backup? This will help us to troubleshoot.
Chear Huat.
I am having the same pop up problem when clicking on Item master. I get error occurred while generation entity view etc..
Maybe I will just stick with the vanilla ice cream release of 2014.
Hi mdellunto,
Regarding the error illegal characters item issue, it has been fixed. Please raise a support case with the product support to request for a fix for Vault 2014 SR1.
