System is a 2008r2/SP1 server running SQL 2008r2 SP1 standard.
Basic vault 2013 with a 4GB vault, libraries approx. 5.5GB and 55GB of File store.
I wish to migrate the existing Libraries and perform and upgrade to the current vault server.
Items to be completed:
Upgrade the license server?
Patch the SQL to SP2, (this appears to be a requirement and it appears that the 2013 vault doesn't support SP2?), so is there a specific order to doing the SP2 patch?
(i.e. does the current vault server need to be uninstalled before installing sql SP2?, or can the SQL be patched without affecting the Vault?)
Upgrade the Vault, it looks like this process required the uninstall of the current vault server then the installation of the new vault server?
Thank you in advance for any suggestions.
Try seeing if this will help.
