Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Vault 2013 Error : Exception has been thrown ..... & Error updating file links
4 REPLIES 4
1343 Views, 4 Replies
For 2 weeks ago we started to have errors messages with Vault 2013 Basic when get/extract files.
Errors Messages :
- Exception has been thrown by the target of an invocation.
- Error updating file links.
After the installation on August 24th all was OK.
Windows server 2003 32bits full patched, SQL 2008 R1
All workstation on Windows 7 64bits / all the hot fix installed
.Net 4.5 is not installed.
I think the probs are coming after the windows update , and come worse. To get 600 files more than 2hours.
Anyone the same Problem ?
4 REPLIES 4
Kevin.Jaufmann-Ludwig
Dear jae72,
does this happen on specific files? What kind of files are that? Inventor files?
Did you run the "Update File Reference" command on such files?
Does it happen only on files before the migration to 2013 or also on new files?
Kevin Jaufmann-Ludwig
Technical Support Specialist
Link Name | Link Name | Link Name | Link Name
in reply to: Kevin.Jaufmann-Ludwig
There is only Inventor files. And the problem come on all the type of files (ipt, or idw, or iam sometimes on migrated files sometimes not).
I have run the "Update File Reference" on the entire Vault. Some errors, but i try it again on the file and no errors is coming.
I have remove the last windows updates and its seem to be better.
richiesuk
having the same issue many times recently
vault 2013 pro, inv 2013 pro...
very annoying (also i have to click on the hazed inv and click "try to restore")
BSchubring
in reply to: richiesuk
We are also having this error, I created a thread about it before I found this one.
http://forums.autodesk.com/t5/Autodesk-Vault/Vault-2012-client-error-Vault-2013-server/td-p/3714304
It is happening on the Check-In of AutoCAD DWGs, and is not completely consistent. (sometimes users can get the files into Vault)
