I am trying to upgrade Vault from 2011 to 2012. Everytime I run the install, I get stuck at the ADMS system check. I keep getting the error that a reboot is needed. I have rebooted the system several times and this does not clear the issue. Is there a workaround?
Solved by JorgenBjornes. Go to Solution.
Some program has tiold windows it needs a reboot, but is unable to clear this trigger. This has happened to me with both sql sp's and creative webcam drivers (!).
See http://crackingthevault.typepad.com/crackingthevault/2010/06/vault-server-install-reboot-needed.html for a solution.
Thanks. That did the trick.
