Validation backup delayed more than 10 hours, but backup finished successfuly. We can see in backup log.
23/04/2013 21:30:31 Backing Up Databases... 1/5
23/04/2013 21:31:52 Backing Up Databases... 2/5
23/04/2013 21:31:52 Backing Up Databases... 3/5
24/04/2013 2:07:32 Backing Up Databases... 4/5
24/04/2013 2:07:34 Backing Up Databases... 5/5
24/04/2013 2:14:06 Validating backup databases ... 0/3
24/04/2013 2:14:08 Validating backup databases ... 1/3
24/04/2013 2:14:47 Validating backup databases ... 2/3
24/04/2013 12:14:20 Validating backup databases ... 3/3
24/04/2013 12:22:23 The backup operation has been successfully finished.
We use this command from cmd.
"C:\Program Files (x86)\Autodesk\ADMS 2012\ADMS Console\Connectivity.ADMSConsole.exe" -Obackup -BE:\Backup\ -VUAdministrator -VP[password] -VAL -LE:\Backup\Log_ADMS_Backup.log -S
E:\ is a local folder.
Where is the error?
Thanks!
Solved by JoseLuisCam. Go to Solution.
Solved by ihayesjr. Go to Solution.
It doesn't look like there was an error. Are you scheduling your backups using the Windows Task Scheduler?
If so, take a look at this page: http://wikihelp.autodesk.com/Vault/enu/Community/Tips_and_Tricks/Improving_Time_to_Perform_a_Vault_S...
Hi Irvin.
I have changed the task priority. Provably that's the problem, because with Windows 2003 does not happen.
We will test this night.
Thanks for your support!
Hi Irvin.
The backup works much faster now:
25/04/2013 20:09:57 Backing Up Databases... 3/5
25/04/2013 20:51:25 Backing Up Databases... 4/5
25/04/2013 20:51:27 Backing Up Databases... 5/5
25/04/2013 20:57:39 Validating backup databases ... 0/3
25/04/2013 20:57:40 Validating backup databases ... 1/3
25/04/2013 20:58:19 Validating backup databases ... 2/3
25/04/2013 22:43:32 Validating backup databases ... 3/3
25/04/2013 22:49:13 The backup operation has been successfully finished.
