Gente tengo un problema a la hora de hacer chek in en los archivos de los cuales me dice( You must either move the file into one of the defined search paths or add a new library search path to continue. Que se les ocurre que podamos hacer para que se me libere el comando chek in.???
Solved by cbenner. Go to Solution.
Hi There,
This is a limitation when adding files from Inventor - In order to use files they must be with an Inventor project.
BUMP!!
What do you suggest for this error on a content center part, derived from an iassembly that is clearly in a location within the project search path? We are pulling out hair over here and losing precious time.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
@cbenner wrote:
BUMP!!
UPDATE:
2 distinct corrupt Content Center components had to be removed from the assembly to get past this error. The error message itself still makes no sense, even the corrupted parts were in the project search paths.
Both corrupted parts were published from parts that had been derived from instances of 2 different i-assemblies. In the 4 years we have been using i-assemblies we have had nothing but heartache, and are slowly dismantling all of them and rebiulding the instances as standalones.
Chris Benner
