I am a mentor for a FIRST Robotics team and we would like to use Autocad Vault to manage our Inventor files so we can have students work on multiple parts of the robot assembly at the same time. Is this possible to implement with the provided FRC Autodesk tools? If so, can you provide an explanation of how this can be accomplished?
Evan Smith
If you have vault Basic with your Suite then yes you can. You can start here http://help.autodesk.com/view/VAULT/Help/ENU/ & read about how to install the product. All the information you need is there pretty much. Certainly to get started.
Scott Moyse
Design & Manufacturing Technical Services Manager at Cadpro New Zealand
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
If you would like help setting up or using Vault for your FIRST team I would be willing to meet with you, and help you get started. I am sure I could get some others from the team to help as well if needed.
Depending on your location it might need to be a virtual meeting.
Please let me know if you would to talk further.
mikel.martin@autodesk.com
