Hello Everybody,
Is there a way to unassign an item.
I mean as we assign item there should be a way to unassign it
I am new to Vault Professional
You can delete an item without deleting the file it was assigned from. You have to set the item to Obsolete first.
Not sure if this is the best or only way to do this, or what else it may affect downstream.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Thanks will try that
Turning an Item Obsolete can be difficult, I've never figured out a tried and true method to do it.
You can also delete items as a full rights administrator. Usually it's better to re-assign the item number, though we've yet to run into problems deleteing items for non-items (vendor sub-components primarily).
