Why is it that whenever trying to log-in to Vault Thin Client - this appears:
Whether it's the IP address, using the proper server name, or from a client machine (the screen grab was from the same server where ADMS was installed), its still the same result.
Solved by chearhuat. Go to Solution.
Solved by ihayesjr. Go to Solution.
Did you uncheck the Read-Only option on the login page? The Thin-client doesn't support the Read-only option with a Vault Workgroup server.
Thanks Irvin. Did that as well (untick Read-only), but then it says "Failed to acquire a license".
I assume we would need Vault Office licenses to enable Thin Client for Vault Workgroup?
Hi clastrilla,
Indeed, VOC license is needed.
regards,
Chear Huat.
Thanks Chear. Can I suggest clarifying this in the help site. It seems to indicate that it's possible with just VWG.
Thanks!
