Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Thin Client for Vault Workgroup 2014 - Subscription Release 1
4 REPLIES 4
clastrilla
830 Views, 4 Replies
Why is it that whenever trying to log-in to Vault Thin Client - this appears:
Whether it's the IP address, using the proper server name, or from a client machine (the screen grab was from the same server where ADMS was installed), its still the same result.
4 REPLIES 4
ihayesjr
in reply to: clastrilla
Did you uncheck the Read-Only option on the login page?  The Thin-client doesn't support the Read-only option with a Vault Workgroup server.
Irvin Hayes Jr
Sr. Product Manager
Vault - Under the Hood Blog
clastrilla
in reply to: ihayesjr
Thanks Irvin. Did that as well (untick Read-only), but then it says "Failed to acquire a license".
I assume we would need Vault Office licenses to enable Thin Client for Vault Workgroup?
chearhuat
Hi clastrilla,
Indeed, VOC license is needed.
regards,
Chear Huat.
Chear Huat
SQA Analyst
DLS- Data Management
Be sure to check out the Vault Help Wiki!
clastrilla
in reply to: chearhuat
Thanks Chear. Can I suggest clarifying this in the help site. It seems to indicate that it's possible with just VWG.
Thanks!
