Greetings!
I'm working with ECOs. When I make a comment in Vault Pro 2013 the text appears organized. However, in Vault Pro 2014 the text appears word-by-word without Enter space. In other words, the system doesn't keep spaces when I apply Enter. I show two images to understand, one in Vault Pro 2013 and another one in Vault Pro 2014.
How can I set the program to show text as Vault Pro 2013 sample?
Thank you!
Text Comment in Vault Pro 2013
Text Comment in Vault Pro 2014
I don't believe there is a setting for this. Were the ECO's created in 2013 and then migrated to 2014? It may just be a result of that. I never used 2014, but a new ECO created in 2015 allows the text to wrap when I hit enter.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Thank you for your reply. ECOs were created in different releases. We have a big customer. They are working in two mega-projects, a plant of wastewater and an hydroelectric. In first project was implemented Vault Pro 2013 about 15 months ago, in another one we started with Vault Pro 2014. We recommend join both project, we're working on that, but we need solve the problem in 2014.
Do you have other suggestions?
Thanks again.
I'm afraid I don't since I've never looked at 2014 Vault. Is there any way you can manually force the text breaks?
Chris Benner
I think that is not possible because I already tried with several spaces after the lines. But finally the text does not appears as I would like. I also installed last SP for Vault Pro 2014.
I've duplicated this issue and a defect will be logged.
-Hywell
