Advice most appreciated
TG
To export to Excel, click the "Uses" tab to view it. Go to Files\Export and specify the file type to export to. I tried an Excel... it worked, but took a little tweaking to make it readable. All the data were there, though.
Can't find anything that would let me say yes or no on your second question.
EDIT:
To search within a file: highlight the file pn Project Exporer and use the Search window at the top of the screen. Under options, select "Search File Content". Expant the search window using the double arrow symbol on the left side of the search window. If not already there, use Add Criteria to add File Name to the search options. In File Name type *.*, and the search results will show all files embedded in the file selected. You could also narow that by typing *. ipt, or *.iam... etc. These results can also be exported... though not as cleanly. LOL
For the third,... iam's don't include drawings,... but they can be the children of an idw. To get that list, use the "Where Used" tab. It will show a list of any idw's that use that iam. You can export that just like the Uses tab.
Hope all this rambling helps!
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Thank you for your answer. Somehow I didn't see this answer and your edit... But thanks again
But I cannot seem to get this search to work... I try to follow your instructions but the search result shows all files in the folder.
E.g. I want to find all files that has a custom property Machining = "C" within the assembly 13570.iam.
I highlight the 13570.iam
Under options I check for "Search file content"
Filename *.*
Machining C
Please see attached pic.
What am I doing wrong?
(In the Vault-viewer I am able to find all these files easily by filtering.)
I also should mension that my search-result (in the attached pic in my last reply) gives med all files with maching porperty "C" in the folder (not in the structure of 13570.iam). The files in the structure of my 13570.iam can be in many different folders in the Vault.
I also wonder if I need to enable Content indexing service on my Vault in ADMS to get this result I am after?
I hope I am able to explain what search result I am after... Here is another example of what I want to find:
Let's say I have designed a big factory called Factory.iam. In this Factory.iam I have 20 machines (iams) in the structure. Each machine have their own structure including frames, motors, cylinders, covers, bolt, nuts, etc.
In one search I want to find all motors including in the structure of Factory.iam. The motors are saved in different folders under my standard content in Vault (it can be electric, pneymatic, hydraulic,... motors).
Here is the way I can manage to find this information: I choose my assembly and Export the "Uses" list to excel. Now I have the entire structure in one excel-sheet and I can Filter the columns I want. So in my example over I can Filter the Title-column for "motor" an I have the list over all motors in my Factory. BUT this is rather time-consuming and tomorrow my excel-list will be outdated...
