Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
SQL database & Repliacation
1 REPLY 1
226 Views, 1 Reply
i am learning to work with our Vault. It was really easy to set the wole databases and it works fine, but:
1) What about SQL check. There probably should be some maintanance plan. Do you have any suggestions what shouldn't be missed in it?  And how often do you care about your SQL database? Do you do something more then SQL maintanance plan?
1 a) Can i care only about our main database  or do i need care about all conected sites?
2) Replication status - Do you use some tools to check replication? Or is reading the logs enough? Is there some page where can i learn the errors from logs?
3) Should i defrag and purge the database often? May i do it when clients are conected?
Thank you 🙂
1 REPLY 1
drobbie
Have you looked at the Advanced Configuration Guide?
You can finid it at http://help.autodesk.com/view/VAULT/Help/ENU/
Douglas Robbie
Sr. Solution Engineer
M2 Technologies
www.m2t.com
