Hi all
can i confirm that SQL 2012 server update 2 is not supported for vault 2015.
Thanks MatB
Hi MatB,
thanks for engaging with us in the forums. You can lookup the requirements here.
And yes you are right. SP1 is supported with Vault 2015 and SQL Server 2012.
This is the fact as by the time we released Vault 2015 SP2 for SQL Server 2012 was not released.
We could not test our product with SP2 and therefore we do not support it.
We are in the process of implementing Autodesk Vault 2015. SQL Server 2012 SP2 has been out for some 9 months now and has become our standard for SQL Server. What is the current Autodesk position on SQL Server 2012 SP2? Has Vault 2015 been tested against SQL Server 2012 SP2 now?
If I really have to install a SQL Server 2012 SP1 instance, can I safely apply the latest Cumulative Update for SP1 (CU15)? This would fix all bugs without changing/updating SQL Server functionality.
Regards & thanks,
-Roger
