Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Resctrict file check out
3 REPLIES 3
jparks_79
270 Views, 3 Replies
Hi all,
Got a fairly simple question. Hoping for a simple solution :-).
I have a group of users who have full access to files(check in, check out, change state,...the works). I have another set of users who I don't want to have any access to change files other than to change the file state to release.
Is the a particular authorization that I can choose from the user roles? Seems like no matter what configuration i choose, the user seems restricted unless I give the engineer the same access as the designer.
Thanks for the help!
Jeremy
3 REPLIES 3
olearya
in reply to: jparks_79
HI Jeremy,
This cannot be achieved by roles - you need a minimum level of access to change state which gives you access to modify files.
You can however configure this with lifecycle schemes - simply make a group with read only access to files in WIP and Released etc but full transition rights to change the file state.
Hope this helps.
Allan
Product Manager
jparks_79
in reply to: olearya
Ahhhh...Thanks!
I had not noticed the security tab on the transistion states.
THanks Allan!
olearya
No problems!
Allan
Product Manager
