Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Repairing References - Scheduled task
4 REPLIES 4
JoseLuisCam
472 Views, 4 Replies
I need to run repairing references utility on Vault Server.
Can i run from command line or scheduled task?
Thank you.
4 REPLIES 4
Olaf.Górski
in reply to: JoseLuisCam
Hello infopsm,
please refer to post by Dave Mink on 21-05-2013 http://forums.autodesk.com/t5/Vault-General/Reference-Repair-utility-Command-line-option/m-p/3930341 stating that this utility does not supports any kind of command line options.
Hope it helps
Olaf Górski
herrerh
in reply to: Olaf.Górski
In addition, the reference repair utility needs to be ran from a Vault Client.
-Hywell
Hywell Herrero
Data Management Support Specialist
Product Support
Autodesk, Inc.
JoseLuisCam
Thank fory our support!
chearhuat
Also, with the tighten rules that we implemented for purging, the RRU tool will/should not be used as a regular clean-up task anymore...
Chear Huat.
Chear Huat
SQA Analyst
DLS- Data Management
Autodesk, Inc.
Be sure to check out the Vault Help Wiki!
