Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Reference Repair Utility Crashes
5 REPLIES 5
cmcconnell
623 Views, 5 Replies
When I attempt to run the Reference Repair Utility, I get the attached error, and I need to close re-open it to get control back.
Windows 7
Windows Server 2008
Vault Pro 2013 Update 1
Mechanix Design Solutions inc.
5 REPLIES 5
achintam
in reply to: cmcconnell
Looking at the error message, I am suspecting that the path in either the Path field on the main UI or the Inventor Project File field on the Settings dialog is invalid.  These two fields require Vault path (with forward slash, /).  For example, $/FolderA for the Path field or $/Designs.ipj for the Inventor Project File field.  Please ensure that the path is correct.
Hope that helps.
Anil Chintamaneni (Autodesk)
mollons
Can you provide us with a snapshot of the settings with which you were running the tool?
Specifically to where were you writing your log file?
Scott Mollon
Quality Assurance
Autodesk, Inc.
Be sure to check out the Vault Help Wiki!
cmcconnell
in reply to: mollons
Here it is - I tried 2 locations for the log file: The default, and what is shown in the screenshot. The path of the project file, I copied from the Project File Setting in the Vault Options.
achintam
Can you also please post an image of the main window showing the Server name and Vault?
cmcconnell
in reply to: achintam
Here it is
