Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Project file .ipj will not checkin
3 REPLIES 3
sgold
349 Views, 3 Replies
I have in my vault 2 versions of my designs.ipj file.  So I've done this before.  Now I made some changes (or i think i have) in the last month without having a checkout to the designs.ipj and I want to check in the new version.  So I've tried checkout without download, checked with download then copy over the file in the working folder, but either way vault (basic) won't accept the checkin.  Well, it performs the process, but I still only have 2 versions shown in the vault and the date is still 1 month old.  Help?
Scott G.
Using Inventor 2013/2014 and Vault Basic since 2012
Using Simulation Flow 360 since 2013 (sparingly, bear with me please)
6 years Solidworks (v2006-v2010)
10 years Pro-Engineer (v13-WF2) w/ Intralink (2.0-3.0) w/ Pro/Mechanica
2 years of Mechanical Desktop
AutoCAD since R12
First professional CAD: DrafixCAD
3 REPLIES 3
mollons
in reply to: sgold
Are you sure the project file iteself has changed?
If you do a check-in and Vault detects that the file has not actually changed it will actually do an undo checkout.
Scott Mollon
Quality Assurance
Autodesk, Inc.
Be sure to check out the Vault Help Wiki!
sgold
in reply to: mollons
There's been a date change, but I suppose its certainly possible no actual settings in the .ipj were made.  I didn't purposely make any changes, but its a new installation all around here, so I'm constantly teaking things out, I don't recall making specific changes to the project file. Figured safe than sorry to check in.  Actually nice to know there's that feature to prevent millions of extra copies of the same file stored.  Is it a bit to bit comparison, so even if the file (say its a part file) have different dates, the data inside is compared?
Scott G.
AutoCAD since R12
mollons
in reply to: sgold
Vault has logic to handle any changes due to dates only changing.
There are number of things Vault uses to determine whether a file has change or not and dates are accounted for in that process.
Scott Mollon
Quality Assurance
Autodesk, Inc.
