Does Vault Basic 2014 support Plan Design? Or is an upgrade to Workgroup/Collaboration/Professional required?
i know with the Plant 3d 2013 extension 1 vault workgroup and higher was required
i will have to check to see if autodesk got rid of that in 2014
DarrenP
Depending on what version you are talking about (2013 or 2014), with 2014 basic is not supported.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
I found that document as well, but a question still remains - which edition of Vault (other than basic) is required?
workgroup or profressional
DarrenP
It has to be workgroup or professional, because the colaboration version is not longer available in 2014.
I would talk to your VAR to see if workgroup will work for you or if you need to bump up to Pro.
