Hi desidubajic,
Currently, we do not support Office 2010 x64, you may refer to this discussion thread for more insight.
Chear Huat.
Hi desidubajic,
I'm hesitating to ask you to try repair again, and ensuring you repair Vault only.
Let us know your result then...
Chear Huat.
Hi There,
i am glad to see i am not the only one whit this problem.
can you give met the exact name of the folder so i can delete it.
thanks
Hi desidubajic,
The file is located in %appdata% folder, this is the path:
%appdata%\Autodesk\Autodesk Vault Professional 2012\Objects
C:\Users\{username}\AppData\Roaming\Autodesk\Autodesk Vault Professional 2012\Objects\Preferences.xml
Do backup the file before deleting it, as it stored all the local vault environment settings, eg. customisation to the column width in Vault Client, etc.
Hope it helps.
Chear Huat.
do you see the icon to log in or does it looks like this: http://ww3.cad.de/foren/ubb/Forum293/HTML/000718.shtml#000003 ?
If you couldn't see it, it is be possible that you habve the same problem like i had with Inventor/Vault2011.
You have to go to the Addin-Manager and enable the vault-addin an the click with the right mouse-button an then enable the hidden addins. The you can enable the "EDM Addin".
Best regards
Michael
oops
Okay,
problem solved........
vault project was switched to single user...........
thanks everyone for the support
BUMP, for the attention of Autodesk
thanks desidubajic you have helped me today!
... having had a meltdown of Vault Add-ins from inside Inventor 2012 today for no apparent reason, and having searched Autodesk supporting documentation (see note 1 and 2 below) , various solutions and recommendations, carry out of uninstall, reinstalls of inventor and vault to no avail etc) i discovered that none of the documentation i found was able to remedy the situation for me until this simple 1 minute fix was discovered.
i wonder if Autodesk would like to add this little bit of magic to one of these following pages?
1. page of interest, no help for 2012 and onwards:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13404176&linkID=9242018
2. another page of interest, no help for 2012 onwards;
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13909656&linkID=9242018
as a closing note, i wonder if this is worth some investigation as far as Autodesk having some supporting resources? eg we had an addin repair utility available pre 2012. would it be worth someone putting in some effort on this specific topic to make a similar utility for 2012 and onwards?
many thanks.
