Hey guys,
I just added a new Idea to the Idea Station, for those who use ECO's with Item Master. The idea is to add the ability to go directly to the Item Editor from the ECO, basically it would be a step saver and IMHO would increase productivity. Check it out and add your kudos if you think it's a good idea...even if you don't. 😉
http://forums.autodesk.com/t5/Autodesk-Vault-IdeaStation/idb-p/2/tab/most-recent
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Solved by cbenner. Go to Solution.
This post was informational only to draw attention to the Idea.
Chris Benner
Hello Chris...
I've had this on my wish list for several years. I will Kudos it....
If you haven't noticed....If you close out of the CO and look at the preview, you do have the edit available there...it's not ideal, but is quicker than going to the item. See screen shot...
Thanks Steve, but that only highlights another pet peeve of mine. Some things you can do IN the ECO window, some you cannot. And one thing I've noticed... never, ever double click toe ECO.... you can't do anything with it then. Don't know how many times I've been called out to someone's office because they can't do anything with a change order that they "own". I ask them to show me what they did, and they double click it from the Vault window. To me, that should be the same as "Edit". But... we live and learn, eh?
Chris Benner
