Vault General Discussion
Distinguished Contributor
mbodnar
Message 11 of 17 (371 Views)
Re: Markup & Measure toolbar missing in Vault preview
08-08-2013 07:07 PM in reply to: VINCEBALGE4109
Hi Makoto
Same here, a repair or/and un-install/re-install of Design Review 2013 makes no difference on Windows 8
Max
Active Contributor
VINCEBALGE4109
Message 12 of 17 (290 Views)
02-11-2014 01:56 PM in reply to: VINCEBALGE4109
Has anyone come up with the solution to this. We're still seeing this behavior.
I'm setting existing user up with new computer. When I installed Vault & Design Review as the administrator everything works a you would expect.
When the user logs in the markup toolbar is missing. If they go back to their old computer toolbar is there.
The solution put forward was to delete the VaultCommon, Productstream and Autodesk Vault Professional 2014 folders from AppData in their user profile.
That does nothing for the problem. I've also tried deleting anything that looks like it could be related to Design Review from the users profile in AppData.
If I have the User log in to my own computer the toolbar is missing. I works correctly when I'm logged into my own computer.
It has to be something in the users profile or the registry, but I can't locate it. We're not using roaming profiles.
Vault 2014 Pro Build 18.100.12.0 Subscription Release 1
Design Review 2013
PDSP 2014
Vince Balge
Active Member
pcetnar
Message 13 of 17 (252 Views)
02-27-2014 01:30 PM in reply to: mbodnar
Two of my customers are currently experiencing this issue as well (both 25+ seats of Vault Pro).  I logged a case with Autodesk a few months ago and received a response that it was sent to the development team.  I hope a fix is released soon as the ECO tools were a primary reason they upgraded to Pro.
Paul
bharath.kumar
Message 14 of 17 (202 Views)
05-09-2014 02:27 AM in reply to: pcetnar
Hi All - We've identified a root registry key responsible for showing up the Markup components, the markup tool( but the ADR in general) relies on one of the core microsoft component "Preview Handler Surrogate Host".
Please grant full permission to the user/group on the key "HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node", the subkeys underneath controls the visibility of the Markup component.
Bharath Kumar
Active Contributor
VINCEBALGE4109
Message 15 of 17 (187 Views)
05-09-2014 06:53 AM in reply to: bharath.kumar
Thank You! that fixed the problem.
Vince
Active Member
pcetnar
Message 16 of 17 (99 Views)
06-13-2014 12:47 PM in reply to: bharath.kumar
Unfortunately these steps didn't fix the solution for my customer.  Would you happen to know of any other culprits that could be causing their ECO toolbars to be missing?
Paul Cetnar
Active Contributor
VINCEBALGE4109
Message 17 of 17 (94 Views)
Re: Markup
06-13-2014 01:03 PM in reply to: pcetnar
Hi Paul;
The only other thing that seemed to affect the markup toolbar is user accounts and permissions.
I've listed all the things I tried before the wow6432 fix here.
http://forums.autodesk.com/t5/Vault-General/Change-Order-Markup-tool-missing/td-p/4385980/page/2
Vince Balge
Senior Specialist - CAD Systems
ATCO Emissions Management
The information transmitted is intended only for the addressee and may contain confidential, proprietary and/or privileged material. Any unauthorized review, distribution or other use or the taking of any action in reliance upon this information is prohibited. If you receive this in error, please contact the sender and delete or destroy this message and any copies.
You are not logged in.
New button for Platinum & Gold Subscription customers
Gold & Platinum Subscription customers can alert Autodesk if they require assistance with their forum post
Manufacturing Community
Ask the Community
