Hello i am trying to solve this problem:
I maped ACAD atributes to Vault properties - and some properties that i have now in Vault, I need them locked for most of the user... For example I create contract in Vault, create ACAD file with some atributes. Then upload it to Vault. This file will be template for another ACAD files in this contract and i want like 2 atributes (properties) to be locked from this time (like contract number and investor for example...).
Do you have any idea how to solve it?
I have solved part of this problem by ACAD block, atributes and insert it as reference to new files but that's just part of solution.
Thank you 🙂
Solved by mikel_martin. Go to Solution.
You make properties read or write (or both) to an attribute.
But you can not make a property that is only editable by some users.
If the user has the ability to edit the file then they can edit any of the properties associated to the file.
