Hi all,
A customer work with Inventor Routed System (PDSP) and Inventor Professional (PDSU).
He plan to use the Job Processor in order to generate DWF files.
Can he buy a Inventor Suite (PDSS) in order to do that? Or does the routed system entities and FEA analysis in files will block the generation of the DWF file?
Thanks in advance.
Hi Xavier,
As far as I am aware to create viz file you should be fine to use PDSS as the smart objects are simply treated as dumb blocks in standard inventor for the purpose of read only access. It may be worth while checking with the inventor team but I feel this will work.
