Hey guys. I'm running the 2013 PDS. And I used to be able to use the Job Processor, but now when I try to open the .exe, the icon appears on the taskbar, then goes away like it crashed and I never see the window open. Does anybody have an idea on how to reinstall it or fix it? I checked the process when I try to open it, but memory pops up around 12,000K, then disapears.
Many thanks,
Jason
Solved by jsilver266. Go to Solution.
Ok I just found out the problem. I tried to make the reset time for the processor to be .25 minutes in the .exe.config file. I changed it to 1 and now it opens up just fine!
