Vault General Discussion
Valued Mentor
MaximUdod
Message 1 of 12 (622 Views)
Job Processor ignores DWF.create job (DWG AutoCAD)
622 Views, 11 Replies
01-08-2013 02:28 AM
Any suggestions why Job Processor (VP2013SP1) executed on PC with installed AutoCAD 2013 and DWG TrueView 2013 could ignore the {DWF.create:*.dwg} job?
The "Update Local" works just fine.
in JobProcessor.exe.config there are 6 lines that contain "DWG". Only two of them are about DWF and there is no AutoCAD or Trueview mentioned in them:
<jobHandler class="Autodesk.Vault.DWF.Create.dwg" handler="Connectivity.Explorer.JobHandlerDwfPublish.InventorDwfJobHandler, Connectivity.Explorer.JobHandlerDwfPublish"/>
<queueDwfCreateJob extension=".dwg"/>
Do I have some corrupt config file?
Employee
chearhuat
Message 2 of 12 (603 Views)
Re: Job Processor ignores DWF.create job (DWG AutoCAD)
01-08-2013 09:34 PM in reply to: MaximUdod
Hi uma,
Could you help to elaborate on 'DWG job creation' is being ignored?
Meanwhile, you might do a simple workflow check, to determine if Job Processor is indeed working.
1. Run Job Processor in your local machine, via Start > Autodesk > Autodesk Data Management > Tools > Autodesk Job Processor.
2. Via ACAD (as reported in you case), check in a simple dwg file, and send the dwf publishing job to job server (via Check In > Settings > Send to Job Server )
3. Via Vault Client, check if the DWF file has indeed been created. You might have to turn on VE > Option > Show hidden file, to examine dwf/dwfx file.
Let us know if that helps...
Chear Huat.
Chear Huat
SQA Analyst
DLS- Data Management
Be sure to check out the Vault Help Wiki!
Valued Mentor
MaximUdod
Message 3 of 12 (599 Views)
01-08-2013 11:49 PM in reply to: chearhuat
Thats the problem - job stays in queue with pending status.
At the same time DWF.create jobs for Inventor files are processed just fine....
subsales
Message 4 of 12 (596 Views)
01-08-2013 11:58 PM in reply to: MaximUdod
Could you send us the config file, and also help to validate if job type 'autodesk.vault.dwf.create.dwg' is checked (should be, by default) in Job Processor > Administration > Job type?
thanks.
Chear Huat
Valued Mentor
MaximUdod
Message 5 of 12 (591 Views)
01-09-2013 12:17 AM in reply to: subsales
Yes the job is checked. Please find the config file attached.
Employee
chearhuat
Message 6 of 12 (585 Views)
01-09-2013 12:52 AM in reply to: MaximUdod
Hi
just examained your config file, it seems okay -- except a couple of commented line (see attached for the original config file) which shall not affect the running of job processor. You could try to rename your current config file and place the attached config file (default) in the same location. Let us know if you're still seeing the sam problem.
Also, you should be able to find JobProcessor.log in the same folder of config file. Could you identify which time that you experience the said error, and attach the log file along?
Appreciate your patience...
Chear Huat.
Chear Huat
SQA Analyst
Valued Mentor
MaximUdod
Message 7 of 12 (582 Views)
01-09-2013 01:00 AM in reply to: chearhuat
With your config the problem still actual.
The job just stays in queue with "Pending" status.
Log file contains no new lines since 6 Jan.
Employee
chearhuat
Message 8 of 12 (568 Views)
01-09-2013 10:23 PM in reply to: MaximUdod
Hi Uma,
One more validation: could you start and run TrueView 2013?
under the hook, Job Processor uses True View for DWF publishing job of ACAD drawign files.
Chear Huat.
Chear Huat
SQA Analyst
Valued Mentor
MaximUdod
Message 9 of 12 (562 Views)
01-09-2013 11:16 PM in reply to: chearhuat
Yes - DWG Trueview 2013 starts susscessfully.
And yes - AutoCAD DWG files could be opened with it.
Employee
chearhuat
Message 10 of 12 (558 Views)
01-09-2013 11:26 PM in reply to: MaximUdod
Do you have a secondary machine that allows you to do some cross-checking.
It could be an isolated case, and is machine specified.
regards,
Chear Huat.
Chear Huat
SQA Analyst
You are not logged in.
New button for Platinum & Gold Subscription customers
Gold & Platinum Subscription customers can alert Autodesk if they require assistance with their forum post
Manufacturing Community
Ask the Community
