Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Job Processor Error
2 REPLIES 2
267 Views, 2 Replies
Job Processor Error
Dear Sirs,
Job processor error, please, see the attached image.
All of aplication runs well, clients, webclients, attaching qeue,...
Server 2003 R2 SP2
Client Vista x64 SP2
I'm going toy try with client XPx32
2 REPLIES 2
youc
Did you try to update view for the files locally? If local updating fails, then Job Processor will not succeed.
If local updating fails, following steps might be of help to troubleshoot:
1). check whether dwf files can be published while checking in via Inventor addin
2). check whether user has enough permission
If local updating succeed, it could be the problem of Job Processor. The basic requirement for Job Processor to work is that Inventor application be installed at the same machine as Job Server and work well in publishing dwf files.
Hope it helps!
Carol
I have installed ADMS in port 8008, although I put the server correct in job processor, it doesn't run.
Instalation with Default port, runs well.
Thanks, regards
