Hello All,
Has anyone out there SUCCESSFULLY managed to set up the job processor to:
1) Update Revision table data to a Rev Table on a .dwg (ACAD or Inv.dwg) file?
2) Create the DWF of a .dwg (ACAD or Inv.dwg) which contains a Vault Rev Table?
Please note: Not looking for general Job server or processor set-up help: I have it all working beautifully with INVENTOR .idw files - the problem is only with ACAD files.
The errors the job processor returns on these files are either:
"Retrieving the COM class factory for component with CLSID {C343ED84-A129-11D3-B799-0060B0F159EF} failed due to the following error: 8007007f The specified procedure could not be found. (Exception from HRESULT: 0x8007007F)."
or:
"Unknown error during publish."
If anyone out there has figure out how to make this work yet, PLEASE chime in - THANKS!
I am running Vault Pro 2013 SP1
James
Hi JNORDGREN
Please search Rev tables:
http://help.autodesk.com/view/VAULT/2014/ENU/
Have you configured your rev tables properly?
As for the question regarding the job processor creating DWF files. You may consider to uninstall DWGTrueView, and reinstall it from the installation media the retest to see if the issue goes away.
Feel free to update the case.
