When I'm in Item Master view (Vault 2011 Pro), the row height is about 4 times the text height. If I go back to Vault Explorer, it's fine. How can I reduce the row height to normal?
Solved by herrerh. Go to Solution.
Have you tried to Right Click in the column headers and select Cutomize View, then do a Reset to get it back to the system defaults?
-Hywell
