In my company we require the Stock Number to be unique. Is there a way to prevent a user from checking in files that duplicate the stock number of something already in Vault?
Right, hence my question. We already have unique filenames turned on. Is there a different way to enforce a unique stocknumber?
Users will be checkign files in via the Inventor Vault addin.
Not out-of-the-box, you might be able to write some iLogic code to do this. I was even thinking of iPropWiz but didn't see any feature for unique values. I know that Vault's Item Master is limited to name uniqueness. This might be a good request for Autodesks Vault ideastation.
Alternatively, is there a way to find all items with duplicate stock numbers? This wouldn't prevent creation of them, but it would help me identify them.
if your question is how to find duplicate stock numbers, that is eazy. you can set some properties map in the vault, and search by specific properties you want to check.
that is manual work, and maybe the borring jobs for CAD administrator.
alternatively you must create some script to handle this jobs.
Internally we use one number format. Externally we have to use another number format. We don't get much say in this due to who we work with.
The numbering schemes depend on the job. It's not something that can easily be assigned programmatically, but checking for duplication should still be possible. I wish this was a supported feature, but it looks like we're going to have to write a program just to look for duplicates.
we have the same problem as we allocate drawing/part numbers and warehouse stock numbers to an item(which are duplicated in our SAP system for buying parts).
To stop duplicates arrising we have been painstakingly doing a set search criteria to get the next number available and checking for duplicates.
This is something that should really be a tick box for checking duplicates tab , where you just tick the property that needs checking.
