Hi.
I would like to insert an hyperlink into the Transmittal File Report template so that the user can click on the file name and open the file from the transmittal file.
Is this possible?
Thanks in advance
Hi Criccardi,
This is technically possible by adding a hyperlink in a client report definition file (RDLC).
You'll need to build a expression to the file's path within the file name field.
The Microsoft Developer Network (MSDN) website would be a good start to guide you through setting this up.
http://msdn.microsoft.com/en-us/library/ms251671(v=VS.80).aspx
