Hi Everyone,
i am after some help on installing Vault 2014 onto win server 2012,
i have followed the Advanced config guide and i cant get past the pre-checks
-running SQL Standard 2012
ASP.NET precheck is failing
the attached document details what i have done and tried
any help would be apreciated
James
Solved by samuel.seah. Go to Solution.
Hi James,
Will you be able to remove the IIS feature and then do a new configuration based on the following?
Samuel
Thanks for that,
this has worked with the features you have suggested,
steps to fixing are as follows,
uninstall all iis features,
reboot,
install all features suggested above,
I did run the installation again after this and I still got an error about unable to access static file, another reboot and the system check went through with out a problem.
thanks again
