In above document, It says that "Link from Vault allows the user to select a file in Vault to be linked into the current Revit Project".
But there is no such "link from Vault" button on the Vault ribbon in Revit.
It talks about opening Revit file from Vault.
Also, the "Open from Vault" button is missing on the Vault ribbon in Revit.
Any comment? Thanks.
Solved by DarrenP. Go to Solution.
i think you have to install this from subscription center: Autodesk Vault 2013 Revit Integration Enhancement
DarrenP
