I am trying to follow the Advanced Configuration Guide for Vault Server 2014 in installing the necessary IIS components.
On page 12 of this document it illustrates what Roles should be selected in Fig 7. Then in Fig 8 on the same page the illustration says to verify your selections. These two Figures do not match. Fig 8 has more roles selected than are shown being selected in Fig 7 (see attached image).
Which is correct?
Solved by samuel.seah. Go to Solution.
Thanks for pointing this out. Please see the following images for the correct configuration. I'll get the team to update the guide.
Samuel
Thank you for clearing that up. I have saved the images to update my downloaded guide with.
I had already started building up this server before and was to the point of applying SPs to the new Vault install when things went bad.
We ended up reimaging the server and I am starting over. So I am trying to follow your guide very closely because it was this IIS component not being correct that seemed to have been the problem before.
If you don't mind I have a couple more questions that pertain to the instructions in this guide and there need and/or order.
Thank you for your help
Samuel
