I have a problem with showing dialog for downloading files using
public static AcquireFilesResults Autodesk.DataManagement.Client.Framework.Vault.Forms.Library.AcquireFiles(ProgressAcquireFilesSettings settings) method.
I am just setting a file to be acquired in ProgressAcquireFilesSettings, but dialog appears only in "LIght GUI" mode (http://wikihelp.autodesk.com/Vault/enu/Help/Help/0378-Develope378/0379-Vault_De379/0380-VDF_Feat380/...
How to show it in "Full GUI" mode?
Mike
Solved by Redmond.D. Go to Solution.
Mike,
Can you please post this issue in Vault Customization forum at http://forums.autodesk.com/t5/Autodesk-Vault-Customization/bd-p/301 ?
Senthil
The quick answer is that you want to use the InteractiveAcquireFileSettings. You can find some sample code in this blog article.
