Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Files not showing in Vault
7 REPLIES 7
Message 1 of 8
tmccar
3365 Views, 7 Replies
I am logged in to Vault 2011 Pro client, and the vault is empty. But in Autocad and Inventor, when I log in to the same vault, I see a dwg file and an ipart. Why is this?
    I trird refreshing the vault client, also logging out and in again.
7 REPLIES 7
Message 2 of 8
CAD-One
in reply to: tmccar
I would think its got to do with folder permissions? But then not sure also, because you said you see it in vault-add-in thru CAD.
Lets see some else has any comments..
C1
Inventor Professional 2020
Vault Professional 2020
AutoCAD 2020
Message 3 of 8
JamesMcMullen
in reply to: CAD-One
When you select your folder on the right side to you see two panels on top of each other or just one?  Sometimes, I have seen where the tab area is overwrites the file location and you just need to scroll the bar down.
-Jim
James McMullen
Principal SQA Eng.
Message 4 of 8
CAD-One
in reply to: JamesMcMullen
You mean adjust (pull up / down) the view pane slipper?
C1
AutoCAD 2020
Message 5 of 8
JamesMcMullen
Correct, I found sometimes that gets stuck.
-Jim
James McMullen
Principal SQA Eng.
Message 6 of 8
tmccar
No, the folder is definitely visible on the right
Message 7 of 8
ihayesjr
in reply to: tmccar
Look at your image, you have a filter set for your view.  If you look at the icon to the right of the search box, you will see a filter icon.  Try clearing your filter settings.
Irvin Hayes Jr
Sr. Product Manager
Autodesk, Inc.
Vault - Under the Hood Blog
Message 8 of 8
tmccar
in reply to: ihayesjr
Yes, that's the one Irvin, thanks!
