I am trying to export BOM from Vault using Export Wizard, but it is showing error "The operation has timed out" (see attached image).
For small assembly it is working fine but for Assembly having approx. 900 parts it is showing the error.
Let me know if any solution available for above error.
System:
Model : HP 2600 Workstation;
Processoer: Intel(R) Xeon(R) CPU
RAM : 24.0 GB;
System Type: 64 bit Operating System;
Graphics Card: NVIDIA Quadro FX 1800;
Vault: Autodesk Vault Professional 2011.
Inventor: Autodesk Inventor Professional 2011
Solved by Andy.Spivey. Go to Solution.
Hareshbhere,
Thank you for the screen shot. Most timeout issue can be resolved by increasing the timeout values listed in the web.config file.
Please refer to page 37 in the Advanced Configuration Guide.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=16853779&linkID=9261341
I hope that information helps resolve the issue for you
Hello Andy Spivey
Thank you very much for your reply.
We increase timeout values and it is working fine.
